Einleitung
Cleaning the inside of your printer with a Q-tip.
Was du brauchst
Safely unplug your printer.
Pull up on the tab to open the printer window.
Note: If you wish to clean more parts on the inside of your printer follow the guide to remove the top cover. This will give you access to more parts. After removing the top cover follow the next steps.
Apply the Q-tip to the three black, cylindrical rollers shown in the picture. Clean them as much as you see fit.
If you notice a lot of dust on other parts of the printer you should clean those as well. For parts with a lot of surface area a damp cloth may be more useful.
Close the printer door (or reattach the top cover if removed), and power on your printer.
