Zum Hauptinhalt wechseln
How to clean the Magnavox MWD200F optical lens
Was du brauchst
  1. How to clean the Magnavox MWD200F optical lens, Faceplate: Schritt 1, Bild 1 von 1
    • Use a Phillips #2 screwdriver to remove the two screws on the top of the device toward the back.
  2. How to clean the Magnavox MWD200F optical lens: Schritt 2, Bild 1 von 1
    • Remove the plastic cover by lifting up the back and pulling it away from the faceplate.
  3. How to clean the Magnavox MWD200F optical lens: Schritt 3, Bild 1 von 1
    • Unclip the three latches on the bottom of the device.
  4. How to clean the Magnavox MWD200F optical lens: Schritt 4, Bild 1 von 1
    • Pull the faceplate off.
  5. How to clean the Magnavox MWD200F optical lens, How to clean the Magnavox MWD200F optical lens: Schritt 5, Bild 1 von 3 How to clean the Magnavox MWD200F optical lens, How to clean the Magnavox MWD200F optical lens: Schritt 5, Bild 2 von 3 How to clean the Magnavox MWD200F optical lens, How to clean the Magnavox MWD200F optical lens: Schritt 5, Bild 3 von 3
    • Locate the optic lens in the middle of the disc drive. Dip a cotton swab in rubbing alcohol and use it to lightly wipe the lens. After the lens is clear of dust and debris, wait a few minutes to let it air dry.
Ziellinie
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Brian
112 Reputation
1 Anleitung geschrieben
University of Maine, Team 1-2, Diaz Fall 2011 Mitglied von University of Maine, Team 1-2, Diaz Fall 2011
UMAINE-DIAZ-F11S1G2
2 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 17
Insgesamt: 2,388
