Zum Hauptinhalt wechseln
Was du brauchst
  1. How to clean the Sega Genesis game port, How to clean the Sega Genesis game port: Schritt 1, Bild 1 von 1
    • Fold fine grit sand paper over a credit card.
  2. How to clean the Sega Genesis game port: Schritt 2, Bild 1 von 1
    • Rub credit card with sand paper up and down vertically inside the game cartridge port.
  3. How to clean the Sega Genesis game port: Schritt 3, Bild 1 von 1
    • Blow out game cartridge port using a can of compressed air.
    • Warning: Do not turn the aerosol can upside down as you spray.
  4. How to clean the Sega Genesis game port: Schritt 4, Bild 1 von 1
    • Rub a Q-tip dipped in rubbing alcohol along the pins of the cartridge slot to remove any remaining debris.
Ziellinie
11 weitere Nutzer:innen haben diese Anleitung absolviert.
Erik Bjornstrom
805 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 3-29, Regan Fall 2010 Mitglied von Cal Poly, Team 3-29, Regan Fall 2010
CPSU-REGAN-F10S3G29
4 Mitglieder
11 Anleitungen geschrieben
4 Kommentare
It worked! I didn't expect it too but it did! Tried it on two old Sega Genesis systems and hooked them up and I haven't had a problem.
Hilary - Antwort
All you need is a slightly worn paper fingernail file. Up & down. Back and forth 1 time. In 6 1/2 years I've never had a console come back to my store. 500 consoles & 10,000 games.
Michael - Antwort
I have a sega genesis 1 the only thing i cant get to work are the conteollers all of them arent connecting i checked the pins and they all look fine. I really want this to work so i can play zombie ate my neighbors
laslidco - Antwort
Worked great for my Sega Genesis Model 2 console (which was super flaky before). Also cleaned my cartridge contacts with rubbing alcohol on cotton swabs, made a HUGE difference. Thank you for this.
fcjohnson65 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 12
Letzten 7 Tage: 80
Letzten 30 Tage: 335
Insgesamt: 33,175
