Einleitung
The XLR connector connects the microphone to the XLR cable which sends signal to the speakers. It is critical that the XLR connector of the microphone is working properly for your microphone to work.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Using a small flat head screwdriver, gently turn the retaining screw at the bottom of the microphone counterclockwise until it stops or provides resistance.
    • Using a small flat head screwdriver, gently turn the retaining screw at the bottom of the microphone counterclockwise until it stops or provides resistance.
    • The retaining screw is mounted to the connector and has a left-handed thread. Turning the screw clockwise locks the connector in place. Turning it counterclockwise lowers it down into the hole, releasing the connector.
    • Once the screw stops, do not try to loosen it further.
  2. Plug an XLR cable into the loose connector.
    • Plug an XLR cable into the loose connector.
    • While holding the disconnect button down, pull on the cable to remove the connector from the body of the microphone.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Schon mal was repariert? Genial!
    Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
    Wir sind alle Genies
  4. Using a detailing brush, gently brush the pins and inside walls of the microphone.
    • Using a detailing brush, gently brush the pins and inside walls of the microphone.
  5. Do not solder microphone parts without prior soldering experience.
    • Do not solder microphone parts without prior soldering experience.
    • Only attempt this step if you have previously soldered inside the microphone. If the pins on the inside of the connector have excess solder on them, take a soldering iron and melt of excess solder.
  6. To reinstall the XLR connector, follow the Installing Shure SM58 XLR connector guide
Abschluss
To reassemble your device, follow these instructions in reverse order. After cleaning the connector, your microphone is ready to connect to XLR cables.
Ein weiterer Nutzer hat diese Anleitung absolviert.
nat coll
384 Reputation
14 Anleitungen geschrieben
Cal Poly, Team 7-53, Forte Fall 2012 Mitglied von Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 Mitglieder
18 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 21
Insgesamt: 3,190
