Einleitung
All of the internal surfaces, especially the conductive metal pieces, need to be clean and well kept in order for the microphone to function at its best.
Was du brauchst
Grab the microphone base with one hand. With the other hand, grab just below the grille (the collar). Twist the collar clockwise to loosen it.
Create a mild cleaning solution by mixing a few drops of dish soap and water in a cup.
Using a detailing brush and the solution, gently brush the pins and inside walls of the microphone.
If you have previously soldered inside the microphone, you may use a soldering iron to melt off any excess solder that may be on the pins inside the connector. Do not attempt this if you have never soldered on the microphone before.
After cleaning the faceplate and reassembling the microphone, it should work at its maximum potential.
Eine weitere Person hat diese Anleitung absolviert.
2 Kommentare
Thanks for the join. I’m checking out the Shure Sm-58 repair. Thanks for the info
Hi I checked the solder on the wires inside the microphone and it still does not work. Any other ideas?
