Einleitung
This guide will show you how to clean the heat exchange cell which Vent-Axia advise should be done once a year.
Remember apart from when you clean the heat exchange cell it should never be turned off.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Turn the heat recovery system off at the wall.
    • Turn the heat recovery system off at the wall.
  2. Remove the 6 screws from the heat recovery panel. You may need a friend to help you lift the panel off and hold the screws for you!
    • Remove the 6 screws from the heat recovery panel.
    • You may need a friend to help you lift the panel off and hold the screws for you!
  3. Remove the internal filter on the left hand side using the pull tab Repeat for the external filter on the right hand side of the cell.
    • Remove the internal filter on the left hand side using the pull tab
    • Repeat for the external filter on the right hand side of the cell.
    • If required clean them using a hoover.
    • Do not wash in water under any circumstances
  4. Gently take the cell by the pull tab You may have to rock it gently to get it out.
    • Gently take the cell by the pull tab
      • You may have to rock it gently to get it out.
      • Gently and slowly is the most important step here.
    • The cell will begin to slide out
  5. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  6. Clean the cell on each side with a hoover to remove any dust
    • Clean the cell on each side with a hoover to remove any dust
  7. Fill a bath with warm water and add a small bit of fairy liquid or similar.
    • Fill a bath with warm water and add a small bit of fairy liquid or similar.
    • Place the cell into the water
      • Gently hold the cell
      • Rock the cell from side to side. Ensure the cell is not scraping the bottom
      • Lift the cell up and let the water drain out.
      • Repeat for each side of the hexagon
      • Remove from the bath and leave to dry
    • Vent Axia tehnical support told me the cell can be a little damp but ensure all water is out the cell.
  8. Clean inside the heat recovery system with the hoover Remove any dead flies
    • Clean inside the heat recovery system with the hoover
      • Remove any dead flies
      • Check the fans for any build up of dust
    • If you have the summer bypass fitted (the white grill) Don't yank it, as its attached via a cable.
      • Gently lift it to clean the fan behind
  9. Begin to insert the cell back in. Slide using the plastic tab Ensure the two black arrows meet
    • Begin to insert the cell back in.
      • Slide using the plastic tab
      • Ensure the two black arrows meet
  10. Put the cover back on
    • Put the cover back on
    • Insert the screws and secure the cover to the MVHR.
    • Leave the internal and external filter out for now
      • We will slide them through the filter flaps later.
  11. Insert the filters into each flap (clean if needed using a hoover)
    • Insert the filters into each flap (clean if needed using a hoover)
    • Close the flap
  12. Turn the heat recovery back on
    • Turn the heat recovery back on
    • It will go through its initial power on so don't expect the fans to start immediently.
    • If you have a message on the screen saying check filters you can clear it (once the filters have been cleaned) by:
      • Waiting until Normal airflow xx% is displayed on the screen
      • Press and hold the up and down arrows for 5 seconds
      • This will reset the cycle for the filter clean. Whenever you see the check filter message clean the filter (remember this is separate to the cell).
      • Keeping your MVHR cleaned to the Vent-Axia recommendations gives you the best chance of having many years of trouble free service.
Abschluss
Your heat cell is now clean. Vent-Axia recommend you clean the cell once a year.
Remember to clean your filters as needed. If you want any extra information all appropriate manuals are attached to this guide.
2 weitere Nutzer haben diese Anleitung absolviert.
Tom
360 Reputation
3 Anleitungen geschrieben
Nice guide! I also found a cool website where you can by replacement air filters for mvhr systems https://filtermate.co.uk
Martin Smith - Antwort
Yes, this was an extremely useful guide. The maintenance manual simply says “withdraw the heat exchanger”, but it was as tight as a gnat’s a**e. Tom’s guide gave me the confidence to use a bit of gentle persuasion. Thanks :)
Terry Ellison - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 20
Letzte 7 Tage: 97
Letzte 30 Tage: 523
Insgesamt: 7,476
