Einleitung
This guide will walk you through the steps to cleaning the Roomba air filter. A clean filter will improve performance and should be checked regularly.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Slide out back bin by pressing the unmarked button on top of the Roomba.
    • Slide out back bin by pressing the unmarked button on top of the Roomba.
  2. Slide out yellow bar on particle bin to access filter
    • Slide out yellow bar on particle bin to access filter
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. This is the air filter assembly
    • This is the air filter assembly
  5. Pop out filter mount by prying 2 points that hold it to the rest of the assembly
    • Pop out filter mount by prying 2 points that hold it to the rest of the assembly
  6. Thoroughly clean or replace the air filter.  This can be done with compressed air or by rinsing it with water.
    • Thoroughly clean or replace the air filter. This can be done with compressed air or by rinsing it with water.
  7. Reassemble the air filter assembly and slide the particle bin back into place
    • Reassemble the air filter assembly and slide the particle bin back into place
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
Scott Leonard
439 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 20-6, Maness Fall 2010 Mitglied von Cal Poly, Team 20-6, Maness Fall 2010
CPSU-MANESS-F10S20G6
2 Mitglieder
Good thing to know this, I can clean my own Air purifier at home my myself. Anyway this is what my air filter like http://ariixproducts.com/puritii-water-a...
top.ariixproducts - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 4,709
