Zum Hauptinhalt wechseln
How to clean your Roomba 4100's air filter.
Was du brauchst
  1. How to clean your Roomba 4100's air filter., How to clean your Roomba 4100's air filter.: Schritt 1, Bild 1 von 1
    • Slide out back bin by pressing the unmarked button on top of the Roomba.
  2. How to clean your Roomba 4100's air filter.: Schritt 2, Bild 1 von 1
    • Slide out yellow bar on particle bin to access filter
  3. How to clean your Roomba 4100's air filter.: Schritt 3, Bild 1 von 1
    • This is the air filter assembly
  4. How to clean your Roomba 4100's air filter.: Schritt 4, Bild 1 von 1
    • Pop out filter mount by prying 2 points that hold it to the rest of the assembly
  5. How to clean your Roomba 4100's air filter.: Schritt 5, Bild 1 von 1
    • Thoroughly clean or replace the air filter. This can be done with compressed air or by rinsing it with water.
  6. How to clean your Roomba 4100's air filter.: Schritt 6, Bild 1 von 1
    • Reassemble the air filter assembly and slide the particle bin back into place
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 20-6, Maness Fall 2010 Mitglied von Cal Poly, Team 20-6, Maness Fall 2010
CPSU-MANESS-F10S20G6
2 Mitglieder
3 Anleitungen geschrieben
Ein Kommentar
Good thing to know this, I can clean my own Air purifier at home my myself. Anyway this is what my air filter like http://ariixproducts.com/puritii-water-a...
top.ariixproducts - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 5,196
