Zum Hauptinhalt wechseln
How to clean/replace buttons on the Skytex SP728
Was du brauchst
  1. How to clean/replace buttons on the Skytex SP728, Case: Schritt 1, Bild 1 von 1
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
  2. How to clean/replace buttons on the Skytex SP728: Schritt 2, Bild 1 von 1
    • Using a small phillips screwdriver, unscrew both end screws
  3. How to clean/replace buttons on the Skytex SP728: Schritt 3, Bild 1 von 1
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
  4. How to clean/replace buttons on the Skytex SP728: Schritt 4, Bild 1 von 1
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
  5. How to clean/replace buttons on the Skytex SP728, How to clean/replace buttons on the Skytex SP728: Schritt 5, Bild 1 von 1
    • Remove the black buttons (they should not be directly attached to the device and may fall out).
  6. How to clean/replace buttons on the Skytex SP728: Schritt 6, Bild 1 von 1
    • On side the circuit board there will be three buttons. One is the power button, and the other two are volume buttons.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Chris Nelson
213 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 5-1, Brown Winter 2015 Mitglied von USF Tampa, Team 5-1, Brown Winter 2015
USFT-BROWN-W15S5G1
4 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 126
