Einleitung
This guide will show how to remove the back cover of the Skytex SP728 and identify the buttons on the side of the device. These buttons are used to raise or lower the volume and to power the device on or off.
Was du brauchst
Make sure the device is powered off
Rotate the device so the ports and screws face you
Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
Remove the black buttons (they should not be directly attached to the device and may fall out).
On side the circuit board there will be three buttons. One is the power button, and the other two are volume buttons.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
