Zum Hauptinhalt wechseln
How to connect Canon PowerShot A4000 IS to computer
Archivierte Anleitung
Diese Anleitung wurde ausschließlich für historische Zwecke erhalten. Verwende die aktualisierte Version dieser Anleitung, um deine Reparatur durchzuführen.
Was du brauchst
  1. How to connect Canon PowerShot A4000 IS to computer, Connecting Your Camera and Computer: Schritt 1, Bild 1 von 2 How to connect Canon PowerShot A4000 IS to computer, Connecting Your Camera and Computer: Schritt 1, Bild 2 von 2
    • Your PowerShot A4000 camera should have come with a USB cable to connect your camera to your computer.
    • The smaller end of the cable is inserted into your camera. It is inserted in the area outlined in red, labeled A/V OUT DIGITAL.
    • To open this area and access the port underneath, place your fingernail under the flap labeled A/V OUT DIGITAL and pull upwards.
  2. How to connect Canon PowerShot A4000 IS to computer, Connecting the USB Cable to the Camera Port: Schritt 2, Bild 1 von 3 How to connect Canon PowerShot A4000 IS to computer, Connecting the USB Cable to the Camera Port: Schritt 2, Bild 2 von 3 How to connect Canon PowerShot A4000 IS to computer, Connecting the USB Cable to the Camera Port: Schritt 2, Bild 3 von 3
    • Simply line up the USB cable and the port on your camera and push the cable into the port until the white casing of the cable is flush with the camera.
    • The other end of the cable goes into the USB port on your computer. To upload pictures onto your computer, you should have installed the CD-ROM included with your camera purchase.
    • If you did not receive this CD-ROM with your camera, contact the place of purchase.
Abschluss
Clemson, Team 1-3, Benson Fall 2014 Mitglied von Clemson, Team 1-3, Benson Fall 2014
CLEM-BENSON-F14S1G3
3 Mitglieder
17 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 1,220
