Einleitung
This guide shows you how to exploit every major function of your food processor—from kneading dough to making instant ice cream—and how to clean and care for the machine so it serves you reliably for years.
Was du brauchst
Schritt 1 Prepare the processor for use
Place the processor base permanently on the countertop to encourage frequent use.
Verify the bowl, lid and blade are securely locked before starting the motor.
Schritt 2 Knead yeast dough
Load up to 500 g of flour and other dry ingredients into the bowl, then add liquids on top.
Drop dry yeast directly on the flour; blooming is unnecessary thanks to rapid mixing.
Lock the lid and choose the highest speed so the motor works at full torque.
Listen as the pitch smooths; when the blade no longer slaps, hydration is complete.
For larger machines rated for 800 – 1000 g of flour, follow the manufacturer’s limit.
Schritt 3 Prepare grated pasta dough
Weigh the eggs, using the built-in or external scale.
Add flour equal to double the egg weight, plus a pinch of salt and a few drops of oil.
Engage the processor; high speed yields small particles, medium speed makes larger ones.
Dough pellets form within seconds; add a splash of water and run slower for bigger farfel.
Schritt 4 Chop small quantities efficiently
Start the motor with the S-blade empty to create the air vortex.
Drop small pieces of onion, garlic, carrot or herbs through the feed tube onto the spinning blade.
Scrape bowl walls with a spatula and pulse again for a finer mince.
Schritt 5 Chop larger batches
Load the full batch of vegetables into the bowl, fit lid and engage lock.
Pulse in short bursts until the desired size is reached.
Schritt 6 Fit the disc and slice or shred vegetables
Install the adapter and a full metal disc; teeth facing up for shredding, knife edge up for slicing.
Feed produce while applying only the pressure needed for movement.
More pressure yields thicker slices; gentle pressure produces very thin cuts.
Roll cabbage leaves into a tight log before feeding for uniform shreds.
Feed carrots vertically for short sticks or horizontally for long strips.
Schritt 7 Control peel and cut length
Place apples peel side up to trap the skin on the lid, or peel side down to include it in the shreds.
Feed zucchini or cucumber gently, adjusting pressure to set slice thickness.
Schritt 8 Shred cheese safely
Guide the cheese so it barely touches the disc, allowing light contact only.
When the last piece is nearly through, release the pushrod and stop the motor.
Schritt 9 Shred frozen chicken breasts
Load fully frozen chicken breast into the feed tube.
Apply gentle, steady pressure; the disc shaves the meat into coarse mince.
Schritt 10 Grind nuts and other oily foods
Combine nuts with a spoonful of breadcrumbs or sugar to absorb released oil.
Pulse until the grind suits your recipe.
Schritt 11 Mince meat in the bowl
Slightly freeze the meat and trim sinews to prevent strands from wrapping the blade.
Pulse in short bursts; an even ball forming around the blade means uniform mincing.
Schritt 12 Whip chilled low-fat milk
Chill 0.5 % milk in the freezer for about an hour so ice crystals form.
Process with the S-blade or whisk until thick foam appears.
Add citrus juice or mashed banana for flavor and body while the foam is fresh.
Schritt 13 Make instant fruit ice cream
Load frozen berries, sliced banana, a few mint leaves and your preferred sweetener into the bowl.
Run at high speed, pausing to scrape down the sides until creamy.
Serve the soft ice cream straight from the bowl.
Schritt 14 Blend hard frozen fruit safely
Verify your processor uses a single-piece blade and a sturdy polycarbonate bowl.
Add up to 500 g of normal-sized frozen strawberries and lock the lid.
Hold the base firmly and run at maximum speed until the rattling stops.
Fold in banana or cream, scrape the walls and blend again for uniform texture.
Schritt 15 Clean and maintain the processor
Wash blades, discs and bowl by hand when possible; occasional dishwasher cycles are acceptable.
Treat the lid’s safety pin gently; a drop can snap it and spares may be hard to source.
Wipe the motor block with a damp cloth only; never submerge.
Clear air vents regularly to prevent motor overheating.
With these techniques and maintenance habits your food processor can knead, chop, shred, grind and whip for decades while staying sharp, safe and reliable.
