Einleitung
Here's how to deregister your VTech SN5107 Handset if the screens is stuck with the message: "Out of range OR No power at base."
Here's how to deregister your VTech SN5107 Handset if the screens is stucked with the message: "Out of range OR No power at base"
Press those keys on the handset:
*331734#
Then press the "Menu/Select" Button
Your handset screen should now show "Registering... Please wait" or "To register HS, see manual", which means it is now ready to be registered to your SN5127 or SN5147 phone base.
Eine weitere Person hat diese Anleitung absolviert.
6 Kommentare
Is there any chance that there's more than one code? This one doesn't work for me although it's clearly the same handset from the video (SN5107) Thanks.
Bonjour Pierre,
Je sais que ce code fonctionne avec les appareils SN5127 et SN5147, mais il est probable qu'il ne fonctionne pas avec les autres modèles. Je vous suggère de contacter le service clientèle téléphonique de VTech; ce sont eux qui m'ont fourni le code pour mon appareil. Bonne chance !
oklair -
Thanks for the response. Appreciate it! I will reach out to Vtech.
