Zum Hauptinhalt wechseln
How to diagnose Samsung Galaxy A40 Charging Problems
Einführungsvideo
  1. How to diagnose Samsung Galaxy A40 Charging Problems, +5V line: Schritt 1, Bild 1 von 3 How to diagnose Samsung Galaxy A40 Charging Problems, +5V line: Schritt 1, Bild 2 von 3 How to diagnose Samsung Galaxy A40 Charging Problems, +5V line: Schritt 1, Bild 3 von 3
    • This is the +5V line from the Charging port to the Motherboard.
  2. How to diagnose Samsung Galaxy A40 Charging Problems, Back cover removal.: Schritt 2, Bild 1 von 3 How to diagnose Samsung Galaxy A40 Charging Problems, Back cover removal.: Schritt 2, Bild 2 von 3 How to diagnose Samsung Galaxy A40 Charging Problems, Back cover removal.: Schritt 2, Bild 3 von 3
    • Warm the device to soften the adhesive.
    • Use Sanction cup, Plastic tools and isopropyl alcohol.
    • Remove the silver Phillips screws from the device's frame.
  3. How to diagnose Samsung Galaxy A40 Charging Problems, Fingerprint sensor: Schritt 3, Bild 1 von 3 How to diagnose Samsung Galaxy A40 Charging Problems, Fingerprint sensor: Schritt 3, Bild 2 von 3 How to diagnose Samsung Galaxy A40 Charging Problems, Fingerprint sensor: Schritt 3, Bild 3 von 3
    • Remove the plastic cap from the Fingerprint flex cable connector and disconnect the cable.
    • Remove the SIM Tray.
  4. How to diagnose Samsung Galaxy A40 Charging Problems, Middle frame removal: Schritt 4, Bild 1 von 3 How to diagnose Samsung Galaxy A40 Charging Problems, Middle frame removal: Schritt 4, Bild 2 von 3 How to diagnose Samsung Galaxy A40 Charging Problems, Middle frame removal: Schritt 4, Bild 3 von 3
    • Use a plastic tool to separate the back cover from the frame. Start from the SIM tray hole.
    • Disconnect the battery.
  5. How to diagnose Samsung Galaxy A40 Charging Problems, Measurement: Schritt 5, Bild 1 von 3 How to diagnose Samsung Galaxy A40 Charging Problems, Measurement: Schritt 5, Bild 2 von 3 How to diagnose Samsung Galaxy A40 Charging Problems, Measurement: Schritt 5, Bild 3 von 3
    • Disconnect the main flex cable and connect the charger.
    • Use a multimeter to measure the voltages at the large end pins of the FPC connector of the charging board. (See the second image)
    • If the reading is okay (~5V) continue with the next step, if not - change the Charging board.
    • Attach the main flex cable and measure the large end pins of the Main flex FPC connector - pic.3.
    • If the reading is okay, continue with the next step, if not - change the Main flex cable.
  6. How to diagnose Samsung Galaxy A40 Charging Problems: Schritt 6, Bild 1 von 3 How to diagnose Samsung Galaxy A40 Charging Problems: Schritt 6, Bild 2 von 3 How to diagnose Samsung Galaxy A40 Charging Problems: Schritt 6, Bild 3 von 3
    • Remove the adhesive rubber around the main flex connector on the logic board.
    • Use some flux and a soldering iron to re-solder the first pin of the motherboard FPC.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
ZFix
191.368 Reputation
330 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
322 Mitglieder
2.545 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 31
Letzte 30 Tage: 186
Insgesamt: 8,028
