Einleitung
extract batt using a drill for better grip
Was du brauchst
To successfully extract a cylindrical dry-cell (e.g. AAA , baby–cell) on which you have no mechanical purchase, and which is stuck in the case because of leaked electrolyte use a manual spiral drill. Drill it through the bottom of the battery to get a grip on it and retract it. Works ! Do not destroy the case by using excessive force.
To successfully extract a cylindrical dry-cell on which you have no mechanical purchase, and which is stuck in the case because of leaked electrolyte use a manual spiral drill.
Drill it through the bottom of the battery to get a grip on it and retract it. Works like a charm!
Counter the drill at the battery-case but NOT against the torch'es topside to avoid structural damage to the torchlight.
2 weitere Personen haben diese Anleitung absolviert.
