Einleitung
This guide will show how to fix squeaky parts on the wheelchair.
Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Locate the source of the squeaking. Typically, this will be one of the rear wheels, castor wheels, or brakes. Clean and remove any dirt or rust from the source of the squeaking.
    • Locate the source of the squeaking.
    • Typically, this will be one of the rear wheels, castor wheels, or brakes.
    • Clean and remove any dirt or rust from the source of the squeaking.
    • You may need to partially disassemble the squeaky part in order to thoroughly clean it.
  2. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  3. Check for improper assembly.
    • Check for improper assembly.
    • Refer to the teardown to check that the wheelchair is properly assembled.
    • Check for proper lubrication. If not lubricated, lubricate thoroughly with bike grease.
  4. Roll the wheelchair around to check if the squeaking has stopped.
    • Roll the wheelchair around to check if the squeaking has stopped.
    • If the squeaking still continues, recheck the chair until the problem is fixed.
Abschluss
Squeaking can be caused by overly tightened connections. If problem still occurs after going through steps, try to slightly loosen bolts (half a turn of the wrench) near the source of squeaking.
Ein weiterer Nutzer hat diese Anleitung absolviert.
Kali Slaughter
207 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 14-8, Maness Spring 2013 Mitglied von Cal Poly, Team 14-8, Maness Spring 2013
CPSU-MANESS-S13S14G8
5 Mitglieder
7 Anleitungen geschrieben
A quick spray of Extralube C60 Trigger Spray will keep the components rust free and spinning for much longer... worth a go www.team-zx1.com
sandraphleb - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 30
Insgesamt: 1,758
