Zum Hauptinhalt wechseln
Wie man Verbindungsprobleme zwischen der Apple Magic Mouse und dem Mobee Magic Charger behebt
Was du brauchst
Videoanleitungen
Ziellinie
30 weitere Nutzer:innen haben diese Anleitung absolviert.
en de
100%
Steffen hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
Dragon Upstream Consulting Limited Mitglied von Dragon Upstream Consulting Limited
Business
1 Mitglied
4 Anleitungen geschrieben
4 Kommentare
I disassembled the Mobee battery pack by removing the 2 tiny screws holding the battery-cover together. One of the batteries had both poles covered with small pieces of greyish tape. Looked like someone forgot to remove them at assembly. I removed the tape. Works well now.
Leuk
BEANTWOORDEN
YatLok Mok - Antwort
I thought I had to buy a new mouse until I found this. Foil proved it. Now for the permanent fix with the solder! Thank you.
Steve Gilbert - Antwort
The batteries inside the mobee are AAA, not AA. I replaced them some time ago :)
Arjen Gerstel - Antwort
I use regular rechargeable batteries, not Mobee ones, but also had a lot of random disconnects. Had read all I could find on the subject but no luck. Finally understood that the problem is on the pointy end of the batteries! So far so good, no more disconnects! Thank you!
cazumanc - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 54
Letzte 30 Tage: 243
Insgesamt: 36,475
