Zum Hauptinhalt wechseln
How to fix SteelSeries Stratus Duo trigger button (L2/R2)
Was du brauchst
  1. How to fix SteelSeries Stratus Duo trigger button (L2/R2), Tools you need: Schritt 1, Bild 1 von 2 How to fix SteelSeries Stratus Duo trigger button (L2/R2), Tools you need: Schritt 1, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • A screwdriver with...
    • a Y 2.0 sized Tri-wing screwhead for the case
    • and Phillips head for the motherboard.
    • Some kind of pry (Prolly your nail 🤣, or your broke-ass credit card might do 💵)
    • Pair of tweezers for delicate tasks
    • Pair of dry, steady hands. (No caffeine for you!)
    Frag FixBot
    Kommentar hinzufügen
  2. How to fix SteelSeries Stratus Duo trigger button (L2/R2), Unscrew and open the case: Schritt 2, Bild 1 von 3 How to fix SteelSeries Stratus Duo trigger button (L2/R2), Unscrew and open the case: Schritt 2, Bild 2 von 3 How to fix SteelSeries Stratus Duo trigger button (L2/R2), Unscrew and open the case: Schritt 2, Bild 3 von 3
    • There are 5 screws in the case, one of them is under the sticker (Circled in red)
    • Pry open from the bottom (Red line) . don't pry from the top (orange line), otherwise, the fastening slot will be damaged. (photo showed in next step)
    Frag FixBot
  3. How to fix SteelSeries Stratus Duo trigger button (L2/R2), This is the slot that I'm saying: Schritt 3, Bild 1 von 1
    • Shown in red line
    Frag FixBot
  4. How to fix SteelSeries Stratus Duo trigger button (L2/R2), Be cautious after opening the case.: Schritt 4, Bild 1 von 2 How to fix SteelSeries Stratus Duo trigger button (L2/R2), Be cautious after opening the case.: Schritt 4, Bild 2 von 2
    • The weight (yellow) is not fixed and can easily drop. Don't lose them.
    • There's a non-functional plastic plug (green circle) that'll fall easily too. Be careful.
    • You will find 2 connections. (red circle)
    Frag FixBot
  5. How to fix SteelSeries Stratus Duo trigger button (L2/R2), Disconnect the connections: Schritt 5, Bild 1 von 2 How to fix SteelSeries Stratus Duo trigger button (L2/R2), Disconnect the connections: Schritt 5, Bild 2 von 2
    • The white strip is the data line. To disconnect, use a tweezer to (1) slide open the black button from both sides , then (2) pull the blue part.
    • The tri-colored wire is the power line. Simply pull it up. (Don't forget it's orientation)
    • Seperate the upper and lower controller case
    Frag FixBot
  6. How to fix SteelSeries Stratus Duo trigger button (L2/R2), Locate the magnet (and put it back if you can): Schritt 6, Bild 1 von 3 How to fix SteelSeries Stratus Duo trigger button (L2/R2), Locate the magnet (and put it back if you can): Schritt 6, Bild 2 von 3 How to fix SteelSeries Stratus Duo trigger button (L2/R2), Locate the magnet (and put it back if you can): Schritt 6, Bild 3 von 3
    • Your magnet won't rattle because it's attached somewhere else inside your controller.
    • Find the bastard and pick it up with tweezers
    • In this step, you may attempt to stick it back to the black encasement. But if you fail so, continue to the next step.
    Frag FixBot
  7. How to fix SteelSeries Stratus Duo trigger button (L2/R2), Go extra mile for the magnet: Schritt 7, Bild 1 von 1
    • Unscrew the 6 screws,
    • Separate the lower analog motherboard first. Beware of the connection (Yellow)
    • And then seperate the upper motherboard.
    Frag FixBot
  8. How to fix SteelSeries Stratus Duo trigger button (L2/R2), Take off the trigger button to access the encasement: Schritt 8, Bild 1 von 1
    • Unscrew these 2 screws (red circle) to detach the trigger button. (From behind, duh!) (P.S. I was lazy and I didn't take photos of the disassembled button and motherboard 😶)
    • You should have good access here. Now yell "GET BACK INTO THE F**KING MACHINE!!! MAGNET!!!" (If you know the reference😏)
    Frag FixBot
  9. How to fix SteelSeries Stratus Duo trigger button (L2/R2), Test the controller before reassembling it: Schritt 9, Bild 1 von 1
    • Reassemble it like lego.
    • Reconnect the cables and try out the buttons with some controller testing site before screwing it back in
    • Did I save the day for you? If yes, have a great day! If not, maybe you missed some steps. ¯\_(ツ)_/¯
    Frag FixBot
Abschluss
当重新组装你的设备时,请按照说明的相反顺序进行操作。
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 33
Insgesamt: 1,054
