Einleitung
Doors are everywhere and provide privacy in a variety of places. If your door doesn't function properly, it is useless. This guide will provide you with easy steps that can be done on your own, in a short time to get your door into tip-top shape. There will be certain steps that may not work the first time around but do not panic, just simply start the step over again. Before starting anything I recommend that you have all the tools needed ready and that you have read the steps at least once. After successfully completing this guide you will have had the privacy of your bathroom restored.
Was du brauchst
Check for any screws that may have become loose over time in your door hinges.
If you found any loose screws on the door hinge, use your screwdriver to tighten them.
Examine the faceplate, checking for any loose screws like you did with your door hinges.
This is your strike plate. Take a look to see if it has shifted, and in what direction it shifted.
In the photo provided you can tell my plate has been shifted downwards.
Make a line on the wall where you will be moving your strike plate. Use something that you will be able to remove, such as a pencil.
Take as many toothpicks you will need to fill up the holes that were created for the previous screw holes, and dip them into the Elmer's glue.
Place the toothpicks into the openings. By doing this, you are preventing your new screws from falling back into the old spot causing the door to be re-positioned again.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
