Zum Hauptinhalt wechseln
How to fix a Chipped Snowboard Edge
Was du brauchst
  1. How to fix a Chipped Snowboard Edge, How to fix a Chipped Snowboard Edge: Schritt 1, Bild 1 von 2 How to fix a Chipped Snowboard Edge, How to fix a Chipped Snowboard Edge: Schritt 1, Bild 2 von 2
    • Apply the snowboard onto a clean and stable surface, making sure it won't move a lot.
    • Clean the board of any dust and dirt.
  2. How to fix a Chipped Snowboard Edge: Schritt 2, Bild 1 von 3 How to fix a Chipped Snowboard Edge: Schritt 2, Bild 2 von 3 How to fix a Chipped Snowboard Edge: Schritt 2, Bild 3 von 3
    • Apply painter's tape around the damaged edge, leaving the damaged edge exposed.
    • This will protect the board while sanding the damaged edge.
    • Always use painter's tape. Regular tape can be damaging to the boards outer coat.
  3. How to fix a Chipped Snowboard Edge: Schritt 3, Bild 1 von 2 How to fix a Chipped Snowboard Edge: Schritt 3, Bild 2 von 2
    • Sand out the chipped area so that the indent is smooth.
    • There should be no more rough edges where the chipped area is.
    • After your done sanding, make sure to clean away any leftover dust with warm water and a clean cloth.
  4. How to fix a Chipped Snowboard Edge: Schritt 4, Bild 1 von 2 How to fix a Chipped Snowboard Edge: Schritt 4, Bild 2 von 2
    • Squeeze out a little epoxy into the chipped area.
    • Use a toothpick to guide the epoxy into the crevasses.
    • The epoxy can be very hard to work with, be slow with it.
  5. How to fix a Chipped Snowboard Edge: Schritt 5, Bild 1 von 1
    • Clamp the chipped area to make sure it stays tight and compressed.
    • Let it stay clamped for 1-2 hours to allow the epoxy to harden.
  6. How to fix a Chipped Snowboard Edge: Schritt 6, Bild 1 von 3 How to fix a Chipped Snowboard Edge: Schritt 6, Bild 2 von 3 How to fix a Chipped Snowboard Edge: Schritt 6, Bild 3 von 3
    • After the epoxy is hard, sand the excess epoxy until it's flush with the board.
    • Carefully and slowly remove the tape.
    • Allow the epoxy to cure for at least 24 hours before use.
    • A full cure is typically achieved between 24 hours and 7 days. Refer to your epoxy container for cure times.
Abschluss
Your snowboard should be good as new, test out your board after it the epoxy fully hardens.
Zeeshan Tanveer
133 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 19
Letzte 30 Tage: 84
Insgesamt: 4,584
