Einleitung
The blown element stops the toaster working, but the wires can be rejoined over the blown section, with very little detrimental effect. See this fix in this video guide
Was du brauchst
Einführungsvideo
Not too difficult, you need patience though.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
this solution worked great for a bout a two weeks, then despite having connectivity in the ribbon, it does not heat up. It sounded like you weren’t expecting your solution to work forever. Did it give out on you after a little bit because of the increased resistance and the crimp?
