Zum Hauptinhalt wechseln
How to fix a blown heater element in a Toaster
Was du brauchst
Einführungsvideo
    • Insert wisdom here.
    • how to fix a toaster
Abschluss
Not too difficult, you need patience though.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
jon
2.928 Reputation
22 Anleitungen geschrieben
2 Kommentare
this solution worked great for a bout a two weeks, then despite having connectivity in the ribbon, it does not heat up. It sounded like you weren’t expecting your solution to work forever. Did it give out on you after a little bit because of the increased resistance and the crimp?
mitchell.drury - Antwort
Mine is still working even after all this time (over 2 years ago). If your heater element is still connected (low resistance) then the fault is somewhere else. Trace the resistance of connections back through the switch to the plug to find the fault.
jon - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 37
Letzte 30 Tage: 116
Insgesamt: 24,936
