Einleitung
This guide is to help fix a garbage disposal if it stops working. Most of the time you just have to clean it and it won’t take long. If that does not work here are eight simple steps to help you fix the problem.
Was du brauchst
Press the red reset button either on the front or on the bottom of your garbage disposal.
Go to your breaker box and look for the breaker for your dishwasher. It may be attached to another appliance. Switch it off.
Using two screwdrivers, place them in the hooks on the top of the garbage disposal and push against them clockwise.
Carefully bring down the garbage disposal from where it was connected to the sink.
Remove the splashguard at the top of the garbage disposal that you normally see from the top of your sink.
Using a screwdriver dislodge and remove any items clogging the disposal. This will give you an opportunity to manually move the blades around.
4 weitere Personen haben diese Anleitung absolviert.
