Zum Hauptinhalt wechseln
How to fix a printer that won't print
Was du brauchst
    • Make sure you have all the necessary tools before you start tearing apart your printer. For this example, I am going to be using an HP ENVY 110 printer. However, it should work for other printers as well. The stuff you need is listed below. Things in bold are required.
    • A screwdriver.
    • A computer.
    • Printer ink.
    • This guide (obviously)
    • When a printer feeds paper for printing, the rollers that transport the paper can sometimes cause the paper to jam.
    • Open the ink access area using a screwdriver (or in my case, my own strength) and locate the carriage access panel (circled).
    • Remove the panel n
Abschluss
Your file should print! If it doesn't, try the above steps again, or contact someone who fixes printers.
2 weitere Personen haben diese Anleitung absolviert.
Lappy4861
183 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 42
Insgesamt: 452
