Einleitung
Does your door sound noisy and rattly when closing, like this? Here's how to fix it!
Was du brauchst
Einführungsvideo
Using a spudger, work off the cap of the first screw. The cap is tight; you may need a jimmy or metal spudger.
Using the flat end of a spudger, remove the airbag emblem. The emblem has clips on the top and bottom -- work carefully.
If you're working on the driver side door, remove the mirror control module. Disconnect it from its wiring plug.
Using a trim tool or similar, begin at the bottom of the door card and pop the card away from the door frame.
After you've released the bottom clips, work your way around.
Disconnect the following from the door panel:
Unlocking cable
Speaker cable(s)
Set the door panel aside.
The door panel is now removed.
You will see the airbag module, vapor barrier, and other components.
Very gently, peel back the vapor barrier to expose the retaining bolt.
Roll the window up.
Inspect the bolt. It is probably missing a nut!
While you're in here, inspect and tighten the bottom bolt.
Look in the bottom of your door and locate the nut that fell off that top bolt.
Replace the nut onto the upper bolt and tighten.
To reassemble your door, follow these instructions in reverse order.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
What is this bullshit? Ever think people may have both bolts there and tightened down still? Ever think other ifixit $@$* may still need to occur? And this is all you have to offer? Awesome thoroughness…
