Einleitung
A simple guide to fix a jammed drive tray on the 360 S, please follow instructions on how to remove the drive from the 360 S first.
Was du brauchst
In the following steps, you will remove the top vent, secured to the top panel by the thirteen clips shown.
Orient the console so that the words "XBOX 360" on the sides are right-side up, and the faceplate is facing to the left.
Insert a metal spudger between the top vent and the top bezel near the rear of the Xbox.
Rotate the spudger away from the console, prying the edge of the fan vent up until the two plastic clips come free.
Insert a metal spudger between the fan vent and top bezel along the left side of the console.
In the same manner described above, begin prying the left side of the top vent away from the top bezel.
Continue prying along the left side of the device, freeing all the clips on that side.
Lift the fan vent up from the freed left side to disengage the clips along the right side.
Remove the entire fan vent.
In the following steps, you will be releasing the six clips highlighted in red.
Insert a metal spudger through the front-most slit on the left edge of the top bezel and between the bottom edge of the clip and the left case, as described above.
Simultaneously rotate the spudger away from the console and pull up on the top bezel to free the clip.
Using the same method described above, free the two remaining clips along the left edge of the top bezel.
Grab the entire top panel with your hands, lift up the entire left edge high enough to rest the separated clips on top of the left case.
Rotate the console so that the rear of the Xbox 360 S is facing to the right, and the right case is facing you.
Insert a metal spudger through the rear-most slit on the right edge of the top bezel and between the bottom edge of the clip and the right case.
While lifting up on the top bezel with your fingers, rotate the spudger away from the console to free the clip.
In the same manner as described in the previous steps, release the middle and front clips along the right edge of the top panel.
Push the latch holding down the hard drive cover to the left.
Pull the hard drive cover away from the console.
Firmly grasp the fabric tab labeled with the size of the hard drive (e.g. "250 GB") attached to the hard drive.
Pull the hard drive straight out of the console.
Insert a metal spudger between the black bottom vent and the silver rim of the bottom bezel, in the rear right corner of the vent.
Rotate the spudger away from the console, prying the vent up from the bottom bezel.
In the same manner as described above, pry the two remaining clips on the bottom right edge.
The clips shown in red can be detached by inserting a metal spudger underneath the bottom edge of the clip. Once underneath the bottom edge, simply prying away from the console will free the clip.
Insert a metal spudger through the slit near the rear left corner of the bottom bezel.
Rotate the spudger away from the device while lifting the rear bezel up with the other hand.
Insert a metal spudger through the left middle slit of the bottom bezel, and between the bottom edge of the clip and the left case.
Simultaneously pull the bottom bezel up and rotate the spudger away from the console to free the clip.
In a similar fashion, free the clip at the front of the bottom bezel's left edge.
Insert the spudger into the rear-most slit on the right edge of the bottom bezel, and wedge it behind the clip by pushing the spudger down while pushing the tip of the spudger against the right case.
Simultaneously release the clip and pull the bottom bezel up.
Insert a spudger between the silver rim and bottom bezel directly above the clip shown.
Release the clip while pulling up on the bottom bezel.
Lift the left edge of the bottom bezel up enough to gain clearance.
Insert a metal spudger behind the left edge of the last clip, and push the clip away from the right case.
Locate the two clips connecting the right and left case along the top edge of the console, behind the Wi-Fi card.
While pushing the left and right case away from each other with one hand, pry the clips away from the case with a metal spudger.
Insert a spudger between the right and left cases to hold them separate while you work elsewhere.
While pushing the left and right cases apart with one hand, free one clip located beside the hard drive slot.
Place another spudger between the left and right cases directly below the clip.
Insert the flat edge of a metal spudger between the left and right cases where the warranty sticker used to be.
Pry the left case upwards to form a gap between the two cases, and slide the spudger in toward the left case.
Rotate the spudger upward to release the last clip.
Release one clip in the front left corner of the top edge securing the left case to the faceplate.
Flip the console over so the bottom is facing upward.
Release one clip in the front left corner of the bottom edge securing the left case to the faceplate.
Rotate the left case away from the device to release the last two inner clips.
Remove the left case.
Release the clip near the front right corner of the top edge securing the right case to the faceplate.
Release the clip in the bottom right corner of the top edge securing the right case to the front case.
Lift the left edge of the faceplate upward to release the last two clips securing the faceplate to the right case.
Detach the faceplate from the rest of the device.
Using a spudger or fingernail, lift the clear blue tab away from the connector.
Slide the locking tab on the power switch board cable connector toward the top of the console.
Pull the power switch cable straight out of the connector.
The faceplate is now free of the rest of the console.
Remove the single T10 Torx screw holding in the wireless card.
Pull the Wi-Fi board out of the console.
Remove the large white sticker from the metal frame to expose a screw.
Remove the five 55.5 mm T10 Torx screws securing the right case to the metal frame.
Disconnect the optical drive data cable from the back of the optical drive.
Disconnect the power cable from the back of the optical drive.
The Drive unit itself
For the lite-on phillips drive, you pretty much have to use brute force and a little prayer. Once you remove the rubber piece near the back (sound dampner and it keeps the drive from wiggling), remove the sponge foam strip at the front (allows the drive to close silently) and the 4 screws at the corners.
You then remove the top piece (some videos will actually have you remove the top spin plate, but that is not necessary). Slide the drive components towards the front, after lifting the front to clear the base pins from the other half of the case.
Then carefully remove the drive tray from the side lips holding it in place, starting from the back of the drive and using it's flexibility to free it one tab at a time towards the front.
Once free you'll notice a small guide pin on the right side (from the front view) near the gears, manually rotate the gears (lowering the lens assembly) until the pin lines up on the far right side (there should be a guide track for it on the bottom of the tray).
Slide the tray back into place making sure the guide pin is properly aligned into the guide track.
You can do a partial reassembly to test the fix, but be careful as the power cord "key" is a molded part of the case, so it can be inserted upside down.
38 weitere Personen haben diese Anleitung absolviert.
6 Kommentare zur Anleitung
Was able to pop tray up on right side out of guide, then moved gears till the pin lined up with bottom of tray, popped tray back into guide. Worked perfectly.
step 35 is not necessary, just gently flip xbox and detach dvd-drive
Thanks for writing this! This guide was really helpful and my xbox is working perfectly again :) never done anything like this before but instructions were clear and I'm pretty happy with myself to be honest. Could do with relevant pictures on the last two steps but overall a really useful and well written guide.
STUCK DRIVE = Need go no further than Step 4. (Photos available)
After removing the top vent you will be able to see a hole in the mesh towards the front.
Beneath the mesh is the side of the DVD case with another hole lining up with hole in mesh. (May have yellow circle around it).
This will need a long thin probe (Nothing I have in my kit) like a perfectly straightened paper clip.
Push the probe through the hole which disengages the lifter inside the DVD player and allows the draw to open.
No need to go past step 4 unless the DVD needs to be opened to remove stuck objects.
