Zum Hauptinhalt wechseln
How to fix water damage in Huawei P8 Lite
Was du brauchst
    • First steps which need to be done in order to restore Huawei phone to the proper state.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Alex Sander
38.219 Reputation
202 Anleitungen geschrieben
10 Kommentare
display of my phone doesnt work time and again even display off button doesn’t work. it gets automatically switched off time and again . does it happy because of water on display ?
Samyog Acharya - Antwort
It is very probable that the liquid damage caused this issues.
Alex Sander -
i have a Huawei P8 Lite 2015 and it got water, everything works fine, but not the display, i did open it up to see if any corrosion on the logicboard but there is nothing so i ran out of ideas to fix it, anyone who had this problem and fixed it plz share how you fixed it
sorry for bad english, i hope you can read it
Magnus Kaas - Antwort
If there isn’t any corrosion then it is probably the faulty display. Try to change the lcd and let us know if it resolve the issue. Best luck!
Alex Sander -
My Huawei p8 life 2017 dropped in the water.I opened the back and used the hair dryer dry it out.after few minutes,it worked.But after seeing the moist in the front camera,I dried it out again with the dryer.Now it is no more working.No matter how I pressed the power button and the volume button.Please any suggestion how to work it on again.Thanks.
Hokolic Chan - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 8,050
