Einleitung
This guide is for tightening and correcting a loose steering wheel on the Logitech G29 Driving Force. This part of the device also replaces the controller for the associated gaming system, so making sure it is working as well as possible for peak performance.
Was du brauchst
Undo the screws on the back of the steering wheel that connect it to the device hub.
Remove the 6 bolts on the faceplate of the steering wheel.
CAREFULLY separate the steering wheel from the base of the device.
Gently remove the wire connector from the steering wheel and remove the steering wheel completely.
Remove the three screws from the locations circled.
Remove the paddle shifter from the device.
After removing the steering wheel and paddle shifter, flip the device hub over and remove the 8 screws highlighted in red.
After the screws are removed, flip the hub back over and remove the black casing to reveal the inside.
Tighten the 4 screws highlighted in orange. This should fix the wobbling issue on your device.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
