Zum Hauptinhalt wechseln
How to force restart your Fitbit Ionic
Was du brauchst
  1. How to force restart your Fitbit Ionic, Force Restart: Schritt 1, Bild 1 von 1
    • Press and hold all three buttons on the Ionic until you see the Fitbit logo.
    • You may notice your screen flash to black for a brief second. Continue to hold all three buttons.
Ziellinie
9 weitere Nutzer:innen haben diese Anleitung absolviert.
Tech Beam Media Mitglied von Tech Beam Media
Business
4 Mitglieder
3 Anleitungen geschrieben
15 Kommentare
More than likely your ionic will brick itself if you do a factory reset, mine did.
gregory_91 - Antwort
This guide does not show how to do a factory reset but rather shows how to force the device to restart.
Carlos Oulman -
Yes I bricked mine too
Paul Keelagher -
Thank you for this. I accidentally discovered this. It took 8 hours to not get this suggestion from Fitbit support.
Natasha ten Krooden - Antwort
Thanks Carlos. My main screen was black this morning. I could swipe to other screens, and found instructions about powering down using the Settings etc, but Settings just stayed on Settings for me, so I had to find some way of using the buttons to restart. I found this! It worked for me. Back to normal after restart.
coopergraham5 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 20
Letzte 30 Tage: 83
Insgesamt: 39,123
