Zum Hauptinhalt wechseln
How to install Ubuntu on the HP Stream 13
  1. How to install Ubuntu on the HP Stream 13, Create a bootable USB drive: Schritt 1, Bild 1 von 1
    • Make sure that you make your drive UEFI compliant, otherwise you will have to turn on "Legacy boot" in the BIOS.
    • Rufus is a good tool to make a quick USB drive. Pick up the freeware tool here: https://rufus.akeo.ie/
  2. How to install Ubuntu on the HP Stream 13, Reboot your computer and access BIOS: Schritt 2, Bild 1 von 1
    • Here is where the tapping begins! Tap repeatedly on the ESC key. If you start seeing the Windows logo you didn't tap fast enough, turn off your computer and try again.
    • You should "Startup Menu" press on F9 to get to the Boot Device Options. From there, select your flash drive using the arrow keys and press Enter.
  3. How to install Ubuntu on the HP Stream 13: Schritt 3, Bild 1 von 1
    • Wait for Ubuntu to load. When you get to this screen press install Ubuntu.
    • It's been known on this laptop for Ubuntu to periodically flash until it finds the right display input. If your trackpad is responsive try restarting the computer.
  4. How to install Ubuntu on the HP Stream 13: Schritt 4, Bild 1 von 1
    • Move the slider until you find the right amount of space you want to give Ubuntu. Plan for about a 5-6 GB installation at the minimum.
  5. How to install Ubuntu on the HP Stream 13, Wait: Schritt 5, Bild 1 von 1
    • Wait until Ubuntu has finished installing and copying new files.
    • Do not remove the USB drive at this time.
  6. How to install Ubuntu on the HP Stream 13, Restart and Enjoy!: Schritt 6, Bild 1 von 1
    • Once all the files have finished copying, you're free to restart your computer.
    • Unplug the USB installer drive only after your computer restarts or when the computer tells you that you can. Files may still be accessed up until that time.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Kevin Fessler
1.831 Reputation
2 Anleitungen geschrieben
4 Kommentare
Bonjour , ma clef n'apparait pas dans le menu de démarrage ...
marclanglois - Antwort
how do you fix the wifi once uuntu is intalled
Shiloh O'Neal - Antwort
i have hp streem 13 and its dont work
ديناصور - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 28
Letzte 30 Tage: 218
Insgesamt: 25,189
