Einleitung
Is your car not starting? Is there a clicking noise when you turn your key in the ignition? If yes, then you have a dead battery. Follow the directions below in order to jump start your car!
Was du brauchst
Pop open the hood of the Insight by pulling the lever located here:
Open the hood by reaching under the hood (in the front and center) and pulling the lever.
Lock open the hood by grabbing the rod and inserting it into the hole on the under side of the hood.
Open the hood of the secondary car, and lock it up into place (with spring-action rod if necessary).
Attach the RED lead to the secondary car's battery where the positive (RED) terminal is.
Attach the other RED lead to the positive (RED) terminal of the Honda Insight's battery.
Attach the BLACK lead to the secondary car's battery where the negative terminal is.
After the Insight has successfully started and has been running for a few minutes, remove leads in reverse order of attachment.
Drive the Insight for at least 30 minutes before turning it off again to ensure a full charge of your battery.
If your car still does not run after all of this, call a mechanic because you may have a bigger problem than a dead battery.
2 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
When I start the engine, the alarm is going on. How to turn it off?
