Was du brauchst
It was cheap so I bought 2 -- only to realize its for an Apple, not for a VGA (VESA) monitor -- too late !
So I improvised.
To mount a VGA monitor, I need to mount the VGA's VESA mount to the desk mount's IMac adaptor
To simulate an IMac mount, cut the metal strip to fit inside the IMac adapter
drill a couple of holes on the metal strip that is big enough to fit a 1/8" x 12mm slotted round head nut and bolt
insert the bolt through the metal strip and the IMac adapter
secure with the nut
drill at least four holes and secure
attach the IMac adapter's metal plate the the back plate of the monitor
secure the back plate onto the back of the monitor
With the IMac adapter secured at the back of the VGA monitor, attach it to the arm
secure with screws provided
the desk mount should have been securely setup on the desk !
That's it !
Let me know if you have any questions or issues.
Eine weitere Person hat diese Anleitung absolviert.
Ein Kommentar
Note:
For other non-Apple IMac monitors (like Dell, HP, etc.), you will need to use a VESA-adapter (or similar) to mount the IMac adapter that came with the DigoTech IMac Desk Mount Articulating Arm (CW-2870)
