Zum Hauptinhalt wechseln
How to open and close a Metabo St EP 455
Was du brauchst
  1. How to open and close a Metabo St EP 455, loosen the cover: Schritt 1, Bild 1 von 2 How to open and close a Metabo St EP 455, loosen the cover: Schritt 1, Bild 2 von 2
    • Make sure the jigsaw is unplugged.
    • Unscrew the bolt holding the guide plate to the jigsaw.
    • Unscrew the 10 screws holding the 2 frame halves together.
  2. How to open and close a Metabo St EP 455, separate the 2 halves: Schritt 2, Bild 1 von 2 How to open and close a Metabo St EP 455, separate the 2 halves: Schritt 2, Bild 2 von 2
    • Separate the 2 halves by slowly prying them apart, going around the edges evenly.
    • When separated, take care of some loose parts.
    • The nut holding the guide plate bolt.
    • Piece of plastic holding some cables.
    • Metal strip pushing the blade back.
  3. How to open and close a Metabo St EP 455, prepare to put the halves together: Schritt 3, Bild 1 von 2 How to open and close a Metabo St EP 455, prepare to put the halves together: Schritt 3, Bild 2 von 2
    • Regardless of how the halves are separated, to put them back together, it is practical to put the saw blade mechanism in the halve with the rest of the parts.
    • Then, make sure the right parts line up and are fitted correctly:
    • The holes for the blade holder. The axis is located on the other halve.
    • The blade driver.
    • The blade guide.
    • The metal strip.
  4. How to open and close a Metabo St EP 455, close it: Schritt 4, Bild 1 von 1
    • Now, add the empty halve on top of the halve containing the parts.
    • Screw everything back together.
Ziellinie
knipwim
8.527 Reputation
30 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 29
Insgesamt: 1,473
