Zum Hauptinhalt wechseln
Dieser Teardown ist keine Reparaturanleitung. Um dein Philips TV 24PFS5242 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. How to open back cover to get access to PCB, Product: Schritt 1, Bild 1 von 2 How to open back cover to get access to PCB, Product: Schritt 1, Bild 2 von 2
    • This is the Philips TV to be disassembled.
    • The stand is actually a loudspeaker and subwoofer system
    • There are no visible screws on the cover other than at the bottom of the stand which does not help to disassemble
    Frag FixBot
    Kommentar hinzufügen
  2. How to open back cover to get access to PCB, Back Cover view: Schritt 2, Bild 1 von 3 How to open back cover to get access to PCB, Back Cover view: Schritt 2, Bild 2 von 3 How to open back cover to get access to PCB, Back Cover view: Schritt 2, Bild 3 von 3
    • The (large) aluminum clip is attached to the back cover and the subwoofer preventing the back cover to come off
    • It needs some force to move, push the aluminum clip towards the subwoofer stand in order to release the two latches holding the clip to the back cover
    Frag FixBot
  3. How to open back cover to get access to PCB, Back Cover removed: Schritt 3, Bild 1 von 1
    • Remvoved back cover with the two holes for the clip latches
    • The back cover itself is just as usual "clicked in" the frame
    Frag FixBot
  4. How to open back cover to get access to PCB, PCB: Schritt 4, Bild 1 von 1
    • Back cover removed giving access to the power supply and main board
    • The subwoofer can also be detached from here
    Frag FixBot
JKL Consulting Mitglied von JKL Consulting
Business
1 Mitglied
4 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 8
Letzte 30 Tage: 120
Insgesamt: 1,211
