Einleitung
Thrustmaster sells spare parts on their online shop website.
You can also contact Thrustmaster technical support to obtain a replacement part if it is not available in your region.
Was du brauchst
Unscrew the 5 screws shown in the first image
Unscrew the 4 screws shown in the second image
Turn the handle over and remove the black cover shown in the 3rd image.
Slowly pull the top half of the stick and rotate it. (Be careful not to damage the wires inside).
To reassemble your device, follow the instructions in reverse order.
100%
Hier starten ›
