Zum Hauptinhalt wechseln
Was du brauchst
  1. How to open up a Nokia N9, remove top parts: Schritt 1, Bild 1 von 3 How to open up a Nokia N9, remove top parts: Schritt 1, Bild 2 von 3 How to open up a Nokia N9, remove top parts: Schritt 1, Bild 3 von 3
    • Click open the USB input protector lid and pull it from the housing.
    • Also remove the SIM card holder.
    • Remove screws from the top using the T3 torx screwdriver.
  2. How to open up a Nokia N9, loosen the screen: Schritt 2, Bild 1 von 3 How to open up a Nokia N9, loosen the screen: Schritt 2, Bild 2 von 3 How to open up a Nokia N9, loosen the screen: Schritt 2, Bild 3 von 3
    • Press your screwdriver against the backside of the white pieces of plastic, and the screen will click out at the top side of the phone.
  3. How to open up a Nokia N9, disconnect screen from phone: Schritt 3, Bild 1 von 3 How to open up a Nokia N9, disconnect screen from phone: Schritt 3, Bild 2 von 3 How to open up a Nokia N9, disconnect screen from phone: Schritt 3, Bild 3 von 3
    • Using a plastic tool, carefully open up the distance between the screen and the housing until the screen is only attached with 2 cables.
    • With the same plastic tool, disconnect the screen cables still attached to the phone.
    • The screen is now separated from the rest of the phone.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
knipwim
7.539 Reputation
29 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 3
Letzten 30 Tage: 16
Insgesamt: 1,145
