Zum Hauptinhalt wechseln
How to prep and clone SSD with MacOS Catalina
Archivierte Anleitung
Diese Anleitung wurde ausschließlich für historische Zwecke erhalten. Verwende die aktualisierte Version dieser Anleitung, um deine Reparatur durchzuführen.
Was du brauchst
  1. How to prep and clone SSD with MacOS Catalina, Prep: Schritt 1, Bild 1 von 1
    • Hardware needed:
    • SSD of greater size than existing used data.
    • Sata SSD to USB adapter
    Frag FixBot
    Kommentar hinzufügen
    • Plug in the new SSD via the adapter
    • Ensure you have Catalina installed currently on your Mac
    Frag FixBot
  2. How to prep and clone SSD with MacOS Catalina, Install Catalina on the New SSD: Schritt 3, Bild 1 von 1
    • Boot to recovery by holding cmd + r immediately after the device boots up. Hold until you see the apple logo
    • Choose Reinstall macOS
    Frag FixBot
    • BE SURE TO INSTALL TO THE NEW DRIVE
    • Do not reinstall to your existing drive
    • The reason to do this is to set up the file structure in the specific way that Catalina needs
    Frag FixBot
  3. How to prep and clone SSD with MacOS Catalina, Disk Utility: Schritt 5, Bild 1 von 1
    • Once the new SSD has catalina on it
    • Exit the setup menu, power off
    • Reboot to recovery mode using the same cmd + R method as before.
    • Use the top menu View>>Show All Devices
    Frag FixBot
  4. How to prep and clone SSD with MacOS Catalina, Clone/Restore: Schritt 6, Bild 1 von 1
    • Since there are two partitions this step will be done twice.
    • Select the new (currently external) SSD that has catalina on it. Select the first partition. I've called my disk MacGuyver
    • Then Click restore and choose the corresponding partition on your existing Catalina disk still installed in the computer
    • Once that is complete Repeat the recovery process for the second partition, this may have the word - Data on the end of the named disk.
    • This step is critical. The goal is to recover your data from the old drive to the new drive. Catalina uses two partitions, so the step must be done twice. This can take a while...
    Frag FixBot
  5. Frag FixBot
    • Once in recovery mode, choose disk utility.
    • At the top left find the option to set the boot disk. This should be the new SSD that you just installed
    • I actually ran first aid on each partition before doing this step. I'm not sure if this was necessary.
    Frag FixBot
  6. How to prep and clone SSD with MacOS Catalina, Boot it UP!: Schritt 9, Bild 1 von 1
    • Restart and it should boot like you never left.
    • Enter your password and login!
    • You can now use your old drive for a backup, time machine, or extra storage now that you have the adapter to use it!
    Frag FixBot
Abschluss
Enjoy the speeds of SSD!
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 33
Insgesamt: 406
