Einleitung
The video in this is not mine. I used it to help me write this.
I will add images/pictures at a later date when I am able to do this again at some point in the future.
Was du brauchst
Einführungsvideo
How to dismantle a Xbox 360 external hard drive.
Get your old xbox 360 External HDD(Hard Disk Drive)
Locate the screws
Remover the Microsoft sticker.
Unscrew the screws.
Push the HDD slightly
Insert it down into the slots. You should hear a slight click if it has been inserted correctly.
Cheaper and less hassle than to get a hard drive for the Xbox 360 Slim and transfer data.
3 weitere Personen haben diese Anleitung absolviert.
2 Kommentare zur Anleitung
If you don’t have the metal tray the HDD it secured too you can still insert the hard drive into the new console although it will be suspended by the connector and will bounce around and could easily become dislodged if the console was moved and you hard drive could fall and end up corrupted.
