Einleitung
It is time to do a wheel distribution if you notice that your skates are less balanced, stop poorly, and that your wheels are not symmetrical. Wheel distribution is a free alternative to buying a brand new set of wheels, and an important part of basic skate maintenance.
Was du brauchst
Set up the skates on a surface that is okay to get a little messy.
The wheels shown in the third photo are very heavily worn. It may be best to simply replace the wheels at this point.
Remove the wheels with the allen wrench. All screws for the pictured boot require a 5/32 allen wrench and are 10mm long.
Once the wheels are removed from the frame place them on your working surface. The basic idea is to take the most worn wheel and swap it with the least worn wheel, and continue.
The pictured swap order (going up/down 2 slots and to the opposite boot) is a common one.
Reinsert the wheel into the frame. Align the wheel with the frame and add the bolt back into the wheel.
Flip the boot over, but be careful to hold the bolt into the frame. Add the 10mm screw to the hole and reattach it with the allen wrench.
Do a final check of your skate. This is a very important step, as an improperly aligned screw is easily missed but can fall out very easily.
All wheels should spin freely. Adding the wheels back into the frame are trickier than getting them out and play a bigger role in your personal safety, so make sure to do that final check. Hopefully, the redistributed wheels will bring back some life into your old skates!
Eine weitere Person hat diese Anleitung absolviert.
3 Kommentare zur Anleitung
do you fix vive headset
vive headset strap. snap on
I can get one side of the bolts off but not the other side. They just keep spinning when I try to loosen them. Any ideas on how to get the rest of the bolts out?
