Zum Hauptinhalt wechseln
How to region unlock your Nintendo 64
Was du brauchst
Einführungsvideo
  1. How to region unlock your Nintendo 64, Top Cover: Schritt 1, Bild 1 von 1
    • Remove the expansion pack cover by pushing in the tab and pulling out.
  2. How to region unlock your Nintendo 64: Schritt 2, Bild 1 von 1
    • If your system uses a jumper pack, the same procedure applies to remove it.
    • A small spoon can be used in place of a spudger.
    • Lever the expansion pack out using a metal spudger.
  3. How to region unlock your Nintendo 64: Schritt 3, Bild 1 von 1
    • Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
  4. How to region unlock your Nintendo 64: Schritt 4, Bild 1 von 1
    • Remove the two front feet of the N64.
  5. How to region unlock your Nintendo 64: Schritt 5, Bild 1 von 1
    • Rotate to top side up and lift off top cover.
  6. How to region unlock your Nintendo 64, How to region unlock your Nintendo 64: Schritt 6, Bild 1 von 2 How to region unlock your Nintendo 64, How to region unlock your Nintendo 64: Schritt 6, Bild 2 von 2
    • Flip the top over and locate the two screws that hold the current slot in place.
    • Remove the slot with a normal Phillips head screwdriver.
    • To install the new slot, simply place the new slot in the same location as the old one.
    • Ensure that the new slot aligns with the opening on the top of the console.
Abschluss
To reassemble your device, follow these instructions in reverse order and enjoy your region-unlocked console.
Additional Information
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Jacob Mehnert
26.703 Reputation
43 Anleitungen geschrieben
iFanatics Mitglied von iFanatics
Community
54 Mitglieder
154 Anleitungen geschrieben
Ein Kommentar
If you don't want to buy a region-unlocked tray, there are two black, square-shaped nubs under the gray cartridge slot covers that can be sanded off with a Dremel tool or sandpaper.
FleshyPie64 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 28
Letzte 7 Tage: 204
Letzte 30 Tage: 981
Insgesamt: 17,698
