Zum Hauptinhalt wechseln
How to remove Alcatel OT-208 SIM card
Archivierte Anleitung
Diese Anleitung wurde ausschließlich für historische Zwecke erhalten. Verwende die aktualisierte Version dieser Anleitung, um deine Reparatur durchzuführen.
  1. How to remove Alcatel OT-208 SIM card, Find the SIM card: Schritt 1, Bild 1 von 1
    • The SIM card is located underneath the battery. For instructions on how to locate and remove the battery, see the guide for Phone Not Charging Properly.
  2. How to remove Alcatel OT-208 SIM card, How to remove your SIM card: Schritt 2, Bild 1 von 1
    • The SIM card is help underneath a metal bracket. The SIM card must be slid out.
    • DO NOT FORCE IT OUT
    • There is a small, red plastic tab at the top of the card.
    • Slightly push down on the tab with one hand and slide the SIM card out with the other
    • Once the tab is pushed down, then you can add a little force. The key is to get the SIM card to slide out.
    • Examine your SIM card.
    • Check for damages such as warped plastic or burn marks.
    • If the SIM card is damaged it will not work
    • Use an alcohol wipe to clean the card
    • Use an air duster to clean where the SIM rests in the phone
  3. How to remove Alcatel OT-208 SIM card, Replace The SIM Card: Schritt 5, Bild 1 von 1
    • Slide the card back in. Make sure the gold chip is faced down and that the cut corner is at the top left of the card.
    • If the device still shows an error you must get a replacement SIM card.
Abschluss
Marie Rolston
537 Reputation
4 Anleitungen geschrieben
USF Sarasota-Manatee, Team 1-3, Stewart Fall 2014 Mitglied von USF Sarasota-Manatee, Team 1-3, Stewart Fall 2014
USFSM-STEWART-F14S1G3
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 179
