Einleitung
Some fabrics can degrade over time with pilling. But this could be removed with a very easy process.
Pilling often appears on winter products like knitted jumpers, merino wool sweaters, knitted 2nd layers like fleece jackets - but can sometimes also be visible on cotton or polyester T-Shirts.
With this repair guide, you will be able to refresh your damaged products to look as good as new!
Was du brauchst
Lay out the garment on a clean surface. Prepare the pilling shaver.
Smooth the garment to make sure it is flat before starting.
Make little circles with light pressure on the damaged fabric. The pilling will be cut away by the shaver.
🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
Be sure to clean the lint from inside your shaver after use.
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
