Zum Hauptinhalt wechseln
How to remove the Samsung LA40R81BD 40in LCD TV rear cover
Was du brauchst
  1. How to remove the Samsung LA40R81BD 40in LCD TV rear cover, Rear Cover: Schritt 1, Bild 1 von 1
    • Unplug power cable and all AV cables from rear of TV and carefully lay TV face down on a clean flat working surface ensuring that you don't damage the LCD screen.
    • Using a Philips driver remove the 18 screws from the rear panel.
    • Gently lift the rear cover off the TV. You may need to wiggle the cover a little however there are no clips holding the cover on so it should come off easily if you have fully unscrewed all 18 screws.
Abschluss
11 weitere Nutzer:innen haben diese Anleitung absolviert.
Richdave
32.081 Reputation
30 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
322 Mitglieder
2.535 Anleitungen geschrieben
3 Kommentare
Got cover off but how to unplug the wires
cpeeledc - Antwort
What size screws holds on the rear panel?
D Mack Miller - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 37
Insgesamt: 24,127
