Einleitung
During sport, a strong stretch can damage the stitching on your jacket or T-shirt. Some seams may break under this heavy strain. Don't worry, they can be easily repaired with a sewing machine and you will be able to continue wearing your favorite outfit for more and more sports to come.
Was du brauchst
Locate the damaged area of your item.
Check how it looks on the outside, and whether it is spreading further by gently pulling the seam.
Also check how the damage looks on the inside, and take note of the type of stitching, and fabric condition around the seam.
Prepare and clean the area around the damaged seam by removing broken thread and trimming any loose threads.
Prepare the damaged seam by placing the fabric edge to edge.
Place the item under the sewing machine, and make a short back-and-forth lockstitch using the reverse lever, to secure one end. Then proceed to make a single long stitch along the seam until the end of the damage. Secure at the end with another locking stitch. Inspect the repair, and if it requires another long stitch, repeat the process.
Tip: check the iFixit basic sewing skills page for more tips on sewing machine setup.
🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
