Zum Hauptinhalt wechseln
How to repair a hole in woven textile (using an iron-on patch)
Was du brauchst
  1. How to repair a hole in woven textile (using an iron-on patch), Prepare and clean the area: Schritt 1, Bild 1 von 3 How to repair a hole in woven textile (using an iron-on patch), Prepare and clean the area: Schritt 1, Bild 2 von 3 How to repair a hole in woven textile (using an iron-on patch), Prepare and clean the area: Schritt 1, Bild 3 von 3
    • Start by ensuring the damaged area is clean and free from any loose threads or debris.
    • Prepare the iron-on patch.
    • Note: in this guide we are demonstrating with a high-stretch patch, to match the stretch of the trousers. There are many patches available, and you should pick a quality closely matching the original fabric.
  2. How to repair a hole in woven textile (using an iron-on patch), Position the iron-on Patch: Schritt 2, Bild 1 von 3 How to repair a hole in woven textile (using an iron-on patch), Position the iron-on Patch: Schritt 2, Bild 2 von 3 How to repair a hole in woven textile (using an iron-on patch), Position the iron-on Patch: Schritt 2, Bild 3 von 3
    • For this repair, we decided to put the patch on the inside of the garment; so the hole will remain slightly visible on the front but will be repaired.
    • Turn the item inside-out, and flatten the area to be repaired.
    • Cut the patch to size, ensuring it completely covers the damaged area. The patch should be 1cm larger than the hole on all sides.
  3. How to repair a hole in woven textile (using an iron-on patch), Iron the patch: Schritt 3, Bild 1 von 3 How to repair a hole in woven textile (using an iron-on patch), Iron the patch: Schritt 3, Bild 2 von 3 How to repair a hole in woven textile (using an iron-on patch), Iron the patch: Schritt 3, Bild 3 von 3
    • Place the glue side of the badge against the fabric. This is often shiny, or with a different pattern.
    • Take care: If the patch is upside-down, the glue will melt directly to your iron and the patch will get stuck to it.
    • Preheat your iron to the maximum heat setting, suitable for your clothing item. Check the composition label for guidance and then adjust the iron accordingly.
    • Gently press the iron onto the cloth-covered patch, applying even pressure.
    • Move the iron in circular motions for about 15-30 seconds.
  4. How to repair a hole in woven textile (using an iron-on patch), Allow to cool: Schritt 4, Bild 1 von 2 How to repair a hole in woven textile (using an iron-on patch), Allow to cool: Schritt 4, Bild 2 von 2
    • After ironing, let the patch cool for a few minutes.
    • Once cooled, carefully check that the badge is properly fixed.
    • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
    • ... however! If you'd like to make the repair extra secure follow the next two steps too.
  5. How to repair a hole in woven textile (using an iron-on patch), Optional: Add a patch on the outside: Schritt 5, Bild 1 von 3 How to repair a hole in woven textile (using an iron-on patch), Optional: Add a patch on the outside: Schritt 5, Bild 2 von 3 How to repair a hole in woven textile (using an iron-on patch), Optional: Add a patch on the outside: Schritt 5, Bild 3 von 3
    • If you want to reinforce this repair, you can choose to add a additional patch on the outside.
    • We suggest to cut a shape with rounded corners to improve the fixation and durability.
    • Get creative: You might also like to cut a customized shape such as a leaf, bear, or heart. Wear it as a badge of pride, to remember the adventure that caused it!
  6. How to repair a hole in woven textile (using an iron-on patch), Finished and ready!: Schritt 6, Bild 1 von 3 How to repair a hole in woven textile (using an iron-on patch), Finished and ready!: Schritt 6, Bild 2 von 3 How to repair a hole in woven textile (using an iron-on patch), Finished and ready!: Schritt 6, Bild 3 von 3
Abschluss
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
Ben Blischke
5.208 Reputation
47 Anleitungen geschrieben
INTERSPORT Mitglied von INTERSPORT
Community
17 Mitglieder
59 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 26
Insgesamt: 105
