Einleitung
Cheap fog machines are often damaged because of their poor quality. Most of this damage can be easily repaired. This guide can be used to repair many common problems that can be encountered when dealing with this type of fog machine.
The fog machine I repaired is called 'eurolite n-19', but it is also sold under other names.
Was du brauchst
Open the fog machine by removing the screws on the sides of the fog machine with the appropriate screwdriver.
Remove the outer casing of the fog machine.
In this instance, all that was needed was a new heat fuse and new spade connectors
In this case, I needed to remove the heat fuse and the spade connectors then needed to connect the new heat fuse and spade connectors to their respective locations
To reassemble your machine, follow the steps for diassembly in reverse order.
7 weitere Nutzer:innen haben diese Anleitung absolviert.
23 Kommentare
My fogger heater is jam how can I clean it?
hmm… I think I could have written a better guide myself. Okay so I have a 3 pin XLR for phase does anyone know how this works also I noted that the fuse was melted into its holster and the pump seems dead. My Fogger also has some kind of potentiometer which controls the heating element which is like a ceramic sandwich and two spark plugs… I also was wondering if glycerin fog juice can be made with vegetable glycerin or the glycol type or if this is what cloggs the machine. Also will clr work or be dangerous fume wise? Can you market glycerine as fog juice thickener like STP fuel additives for cars?? g0pg.xyz is my website you can learn how to force push graphite if you look for the post with yoda!
Where can I buy a fuse like this? Have looked over the net, but could not find any shops that would sell CH-15 fuse, used in this fog machine. If anyone knows about this, please share info. Thanks! By the way, I’m based in EU.
I would make a post on Halloweenform.com
My fog machine is not pumping out smoke
