Zum Hauptinhalt wechseln
How to repair touch [hardware issue] iPhone 6
Was du brauchst
    • In this tutorial you will learn how to resolve hardware touch issue in an iPhone 6 smartphone. In case of any troubles contac me through the comments.
Abschluss
12 weitere Nutzer:innen haben diese Anleitung absolviert.
Alex Sander
38.237 Reputation
202 Anleitungen geschrieben
8 Kommentare
Do you change that ic with new one?
thanks before
aqsha asri - Antwort
No, I have desoldered the proper chip from the other motherboard. Thanks for your interest and best luck with the repair!
Alex Sander -
Is it a good idea to change the whole screen
michael quartey - Antwort
You are right, but sometimes it won’t work. Especially when it is a hardware issue.
Alex Sander -
? the logic board is not attached to the screen ... it has nothing to do with the screen, it is that - processor where one of the soldering points is not making contact and the tutorial shows just reheating to the point the soldering melts again and the crack or whatever that makes the connexion is broken gets fixed again, right?
Sven AERTS -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 18
Letzte 30 Tage: 72
Insgesamt: 11,222
