Einleitung
An Audio/Visual port enables a device to send or receive sounds and images. If these are not coming through, the A/V port may be at fault. If the A/V port is determined to be faulty, this guide will demonstrate how to replace the A/V port in the Konica Minolta DiMAGE Z3. This repair is not only relatively expeditious, but also relatively easy, and requires no major technical skills to complete.
Was du brauchst
Open the battery chamber door by sliding the door to the side of the camera to release the safety catch.
Lift the door up to open.
Insert the four batteries inside of the battery chamber door.
Make sure the positive and negative battery terminals are in the correct position.
Use a screwdriver to remove the four viewfinder cover screws.
Remove the screen cover by applying slight pressure at the top, then pulling the screen protector away from the camera.
Remove 1 screw on the outer side of the battery chamber.
Pull the wrist strap away from the front of the camera to remove it.
Then carefully pull the back casing apart from the camera.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use tweezers to carefully pull the ribbon cable from the circuit board, not from the LCD screen.
Peel back tape on LCD screen to reveal where the wires are attached. Use tweezers to detach the wires from the LCD screen.
Remove the single screw that connects the circuit board to the motherboard.
Carefully remove the circuit board from the motherboard.
Leave the wires attached to the circuit board.
The A/V port is glued to the motherboard. Heat should be applied carefully with a heat gun to loosen the adhesive.
Remove the A/V port with a spudger.
To reassemble the device, follow these instructions in reverse order.
2 weitere Personen haben diese Anleitung absolviert.
