Zum Hauptinhalt wechseln
How to replace a Euro Cylinder in a Mortise Lock
Was du brauchst
  1. How to replace a Euro Cylinder in a Mortise Lock, Measure the cylinder: Schritt 1, Bild 1 von 1
    • Open the door.
    • Measure the distance from the the forend screw holding the cylinder to the faceplate as shown in the picture.
    • Buy the new cylinder.
    • The maximum overhead you can dimension the new cylinder too large is 2mm. If The cylinder sticks out too much it becomes vulnerable to cracking.
  2. How to replace a Euro Cylinder in a Mortise Lock, Remove the screw: Schritt 2, Bild 1 von 1
    • Use a PZ2 screwdriver to remove the fixing screw from the side of the lock.
    • Some older locks might use a slotted screw instead.
  3. How to replace a Euro Cylinder in a Mortise Lock, Remove the cylinder: Schritt 3, Bild 1 von 3 How to replace a Euro Cylinder in a Mortise Lock, Remove the cylinder: Schritt 3, Bild 2 von 3 How to replace a Euro Cylinder in a Mortise Lock, Remove the cylinder: Schritt 3, Bild 3 von 3
    • Insert the key and turn it to about 20° to the right (or left) to release the cylinder from the lock insert.
    • If you don’t have the old key or the cylinder doesn’t work anymore you can give this guide a try.
    • Pull out the old cylinder.
Abschluss
To install the new cylinder, follow these instructions in reverse order.
Sebastian
20.983 Reputation
60 Anleitungen geschrieben
German Translators Mitglied von German Translators
Community
27 Mitglieder
761 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 29
Insgesamt: 278
