Einleitung
A QMR Rail Hook on your hardback panel (attachment hook on the rack) is responsible for the correct positioning of the bike bag on your rack. It can be re-attached or replaced in a few easy steps.
Was du brauchst
To remove the broken buckle, you will need a large flat head screwdriver.
Disassemble: Unscrew the orange dial and remove the damaged QMR rail hook and wire spring.
Push the new washer in and use the screwdriver to move it into place. Place the threaded oval plate and wire spring directly on top of each other. The hole of the threaded plate must be directly above the hole of the washer. Screw on the new QMR Rail Hook.
Finished! You did it.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Daniel Schmid hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
